Inducer Motor Replacement Bryan 90 Plus
rsalway
rsalway Member Posts: 2
I have a Bryan 90 Plus furnace that needs the inducer motor changed. The company that came to look at it wanted $1200. I googled and found that it was an easy job. I ordered what I thought was the right part. Everything fit exactly as it should. The only problem was my wire connection has 4 wires and the new one has 3. Is there a fix or can some point me in the right direction to the correct part?
    EBEBRATT-Ed Member Posts: 20,500
    edited December 2024
    I don't know. You should only need 3 wires to run the inducer, hot-Black, neutral-White and green-Equipment ground.
    Maybe the 4th wire coming out of the motor is a centrifugal switch output to prove motor operation.
    Is there a pressure switch installed on the furnace to prove the inducer is running?
    Look at the manual & the original wiring diagram and find out what the 4th wire does will give you a clue
    Maybe you could provide model # and serial # so it can be looked up.
    mattmia2 Member Posts: 17,492
    probably 2 stage vs single stage
    HVACNUTEdTheHeaterMan
  • worldclasshvac
    worldclasshvac Member Posts: 40
    Thats a two stage inducer and you have a single stage one with 3 wires. Give me the model # and I can give you the correct part #
    HVACNUT Member Posts: 7,529
    $1,200 isn't looking too bad right about now.
  • rsalway
    JE1D017
  • worldclasshvac
    Furnace model # not the inducer model
    EdTheHeaterMan Member Posts: 12,514
    The old inducer motor part number that starts with HC27 AND the furnace model number . I can look it up on the Bryant Dealer website. There may be a new number for the part that says "Replaces HC27?????"
