ThermAtlantic hydronic distributed forced air systems experience?
First, a new posting to encourage response: has anyone used the Therm Atlantic multi-port fan coil unit that has 5 duct connections and in-line fans (recommended to mount above a closet space and route ducts/fans in the attic buried in cellulose insulation)?? Potentially, since I already have ceiling discharge ports, this approach could save on first cost but future maintenance may be an issue. Fan speeds would have to be modulated for fine control of space temperature.
I'm also interested in experience with any other of ThermAtlantic's water-to-air distribution products (e.g., Cased Coils, etc.) and experience with the company., [Note: I don't intend to use their split air-to-water heat pump unit.]
