Gas supply adaptor?
mferrer
mferrer Member Posts: 40
I am concerned about this gas line coming into the house my daughter recently purchased. I am a commercial pipefitter by trade, but am not familiar with this fitting and connection.
I'm uncomfortable with this situation and am surprised it passed inspection. It appears to me that black plastic piping was installed inside old black steel piping that is underground and entering through the foundation without a sleeve. The steel is corroded near the wall and I think I see the plastic piping inside.
I realize this worl requires a shutdown by the gas service. Any recommendations on how to proceed would be appreciated. Am I correct in what I am seeing? Should the adaptor and near piping be replaced? If so, should there be some type of waterproof sleeve installed as well?
Thank you for your help!
    hot_rod Member Posts: 27,329
    gas lines are usually yellow plastic. And yes it should be sleeved. Or go thru the rim joist with a steel nipple.
    Steamhead Member Posts: 18,404
    Is this dangerous pipe before or after the gas meter? If it's before, it belongs to the gas company and is their responsibility. Call them now.
    Consulting
    mattmia2Mad Dog_2
  • pedmec
    pedmec Member Posts: 1,306
    I don't see no plastic gas pipe there. That fitting is an extension coupling from what I can make of it. I don't like the condition of it and would replace it ASAP.
    Mad Dog_2
    mattmia2 Member Posts: 16,462
    I think that is just uncoated black iron coming in through the foundation with some sort of a compression/dresser coupling on it. It was how they did it 70 years ago. None of it is how they do it now because it will eventually corrode and develop pinholes.
    109A_5 Member Posts: 3,889
    edited December 2024
    Hello mferrer,
    I watched that exact procedure or repair being done decades ago. The gas meter was in the basement so that special fitting / interface coupling was on their side of the meter.
    If I recall correctly there was a small leak issue out near the street, at the shut off valve or the connection to the main or just in that area (I was initially unaware of it). Also talking with the workers, at that time they did not want to relocate the meter outside the house, they just wanted to fix the present issue.
    What the Gas company did is they shut the gas off at the street, disconnected the meter and the specialized meter piping bracket, also removed the piping back to the gas service entrance pipe coming through the wall. Out near the street they dug up a small area and cut the service feeder pipe to the house about a foot past the shut off valve (towards the house). Then they used the old steel pipe as a conduit and pushed the plastic pipe through the old pipe (maybe 30 feet). With that special coupler inside the basement it makes a gas tight connection to the new plastic pipe and screws onto the old steel line for support. At the street I believe the new valve and the connection to the main was all done with plastic. The meter and the piping was all reassembled. They may have also re-lit the hot water tank. A week or two later a contractor repaired the minor damage to the lawn.
    Since your daughter's pipe is severely dilapidated I would look into the situation. Or at least temporally support everything so there is no weight on the dilapidated pipe and the plastic pipe. If it is on the Gas companies side of the meter it may be their responsibility and they may repair it, although it is her wall. I suspect it is their responsibility, but the rules often change with time. If it is the home owner's responsibility and the Gas companies inspects it and deems it unsafe they will shut her off and tell her to call a Plumber.
    PC7060
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,523
    I would call a Licensed Gas installation professional ...utlity (free)lor contractor to come and assess before u do or touch another thing. Home inspections are often very rudimentary and done by marginally qualified people. I've come across only a small handful of really sharp guys. It's laughable when people used to call them "Engineer's report." Keep us posted please. Mad Dog
    LRCCBJRevenant
    EBEBRATT-Ed Member Posts: 20,085
    I would call the gas utility. As others have mentioned if it is before the meter it is a utility issue. After the meter (which must have a shut off ahead of it) it would be the homeowner's problem.
    Mad Dog_2
    the ones that are recommended by real estate agents are the ones that will make their job easy, not the ones that will find the stuff that is wrong.
    Revenant
  • mferrer
    Thank you all for the valuable advice. Going to tell my daughter to call the gas company.
