Honeywell CM907 Replacement help
Davhas
Member Posts: 2
in Gas Heating
Hello
Im looking to replace my Honeywell CM907. It appears the T4 is a direct replacement but has no WiFi or app option. I'm looking to see if I can replace with a system that will work with Google Home. Does such a wired system exist? Which can be a straight swap for the CM907 without the need to install a receiver/link.
I can't work out if the T4 pro will be a straight replacement too? Or if that needs a receiver?
Any help would be great!
Dave
I believe the T6 for WiFi. Not sure about Google Home.
Thanks, Is the T6 a straight replacement for CM907 as it looks like the T6 needs a receiver?
Receiver? No. There are some that are RedLink, that requires a gateway and interface, but a TH6220WF2006 is a direct change out.
