Sludge Treat after tuneup
Before I do anything I’ll regret….we already had our oil burner and steam boiler serviced in August. It’s running fine. We are currently at 1/4 tank and are getting our 285 gallon tank filled tomorrow. I have some Sludge Treat and was going to add a pint to the tank today. But am I asking for trouble? I don’t want to loosen up anything and clog the filter or worse. I have used it a couple times in the past year. Not sure how often I should add it. Thanks
  • Lance
    Lance Posts: 344
    AHH Sludge. My favorite nemesis. I learned filters at oil tanks only work when the oil line was always filtered. After a client had his basement jackhammered for a waterproofing piping, his oil nozzle kept clogging. New filter at tank, useless. Had to filter at burner useless. Had to replace the oil pipe. Just too much sludge to filter. 40 years of sludge lining the pipe was not a problem until the jackhammers arrived.
    HVACNUT Posts: 7,784
    How old is the tank?
    Top fed or bottom?
    1 pipe or 2?
    Has sludge been an issue in the past?
    I add this before every delivery I get.
  • Don_175
    Don_175 Posts: 182
    Tank is maybe 10-12 years old. Bottom fed. New coated line. One pipe. I’m just trying to be proactive, but we did have some filter clogging. Our state mandates B10 biofuel.
    @Don_175 If you have been using oil treatment right along and had good results I would continue using it.
  • mrcoder
    mrcoder Posts: 102
    edited February 2025
    Do you have a tigerloop ? The see-through model and the flex tie-ins are supposed to be sensitive to additives and biofuel. Some of these will slowly dissolve the hard rubber and plastic parts over time.
    Whether it is additives or biofuel, the see-through part first gets hazy. This is your first warning.
    Later, cracks may develop, and you may lose integrity. This info is from the Tigerloop tech support people.
    I have no information on how the flex hose deteriorates; I am guessing it may develop an air leak over time.
  • mrcoder
    mrcoder Posts: 102
    How often to add any additive? It is not about the frequency, it is about maintaining the manufacturer recommended ratio of additive to oil.
    For an initial dose, you calculate the amount of additive to add based on how much oil is in the tank. For maintenance, base it on the amount of oil filled, This way you just maintain the recommended dosage/ratio.
    The manufacturers tend to be permissive of using "a bit more" although any harm done to plastic or rubber parts will be worse with a higher concentration.
