Old Beckett tube assembly
KMF
Member Posts: 1
in Oil Heating
My old tube assembly built some time late 80's has a rod inside the nozzle tube assembly. I broke off one end and noticed there is a plug with a small hole on its side. I believe this is called vent plug. Can I installed the new nozzle assembly (AF72XN). The new assembly has a heavier wall thickness but not reduce area like the old nozzle line. My unit is old Beckett with pump that is not fitted with shut-off solenoid valve. Thanks
