Why is the expansion tank flooded? This Friday's video
On this weeks video, it talks about what the expansion tanks keeps flooding Seeya Friday
Boiler Lessons
hmm, that turned out huge.
also piping at the boiler not arranged to encourage the air to go to the tank.
Wow can't put anything past you guys. Hope you enjoy the video. I hate when this happens on a job as it takes so long to discover what you did worked.
Ray Wohlfarth
Boiler Lessons0 -
Hello Ray,
After starting the circulator and the system sounding like it was pulling water and screaming through a clay straw while clawing the inside of the straw with fingernails, what I found was loose packing nuts on the gauge glass of the steel compression tank, 1/4 turn on each packing gland nut and to date in 7 years I have had no issues.
I emptied the coal hopper on Wednesday as the young fellow that comes to clean and tune the coal stoker was coming as I cannot do it anymore due to the pacemaker in my chest as I have to avoid reaching and over exertion as it could loosen the pacemaker leads.
I started the coal stoker and circulator to empty the remainder of coal in the throat of the hopper and there was no noise AKA screeching or bubbles migrating through the boiler for the 2 hours I ran the stoker to empty it more.
