Gas Water Heater Thermostat
Big Ed_4
Big Ed_4 Member Posts: 3,545
Is there a tool to remove and instal the newer thermostats ?
    EdTheHeaterMan Member Posts: 12,448
    I think they surround those in breakable plastic so you need to buy a new water heater when the gas valve goes bad.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,144
    Hi, I see that a number of places on the web suggest putting a 1/2" pipe in the gas port to use as a lever. Seems like a great way to crack the valve, but if you're replacing it anyway… My approach in the past has been to use a big monkey wrench.
    Yours, Larry
    HVACNUT
  • Big Ed_4
    I was hoping for a tool , only the 24" jaws work , and the body is plastic . The 4 plastic tabs that Ed mentioned ? What for ? I thinking the 1/2"nipple for now … Thanks
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,617
    I have used the 1/2" nipple trick. With no issues.
    Larry WeingartenHVACNUT
