Run time
With temps outside at 70 and no call for heat, should my Lochinvar furnace be running at all if there is no call for hot water?
    EdTheHeaterMan Member Posts: 12,041
    Depends, what Lochinvar are we talking about, and how does it make hot water?
    Model number, pictures, any other info???
  • GGross
    GGross Member Posts: 1,846
    Some combi models have a comfort function that keeps the heat exchanger warm. Could be a unit on outdoor reset with a faulty outdoor sensor going into freeze protection mode. Could be an indirect tank dropped temp just enough to get the unit to fire. If you have an indirect the boiler will fire whenever the aquastat or sensor tells the boiler to fire, not only when there is a hot water demand. Need more info and pics help
    HVACNUT Member Posts: 7,411
    More info needed. Some have an internal recirculation setting.
    hot_rod Member Posts: 27,336
    Comfort mode speeds up HW delivery, but costs you more gas. It can be toggled on or off in the DHW menu
