Understanding the PTA gauge, this weeks video
RayWohlfarth
RayWohlfarth Member Posts: 2,035
edited October 2024 in THE MAIN WALL
One of the most common questions I get asked in my classes is how much pressure should be on the hydronic boiler. So this video explains how to determine how much pressure is required. I hope you enjoy it.
Ray Wohlfarth
Boiler Lessons
    EdTheHeaterMan Member Posts: 12,508
    Nice video Ray, I like the part about mechanics believing that the Circulator Pump pushes the water up to the empty radiators. I just reviewed that concept with a new member of HeatingHelp.com. It took several diagrams and comments to get him to realize that the system must be full of water all the way to the top radiator for it to work properly. I wish I had this video three weeks ago.
    RayWohlfarth
    EBEBRATT-Ed Member Posts: 20,482
    4-5 psi at the highest point in the system static with the pumps off. That is if your pumping away from the ex tank. If pumping toward the ex tank and the system had a high head loss you could have a vacuum at the top of the system….seen that many times.
    EdTheHeaterManhot_rodRayWohlfarth
  • RayWohlfarth
    edited October 2024
    @EdTheHeaterMan thank you Ed appreciate it
    @EBEBRATT-Ed Good point Thanks
    Ray Wohlfarth
    Boiler Lessons
    mattmia2 Member Posts: 17,476
    I'd also add the leaking indirect coil or tankless coil to the pressure creeping up without heating.
