Custom Finned-Tube Enclosures Possible?
NTL1991
NTL1991 Member Posts: 108
I've been meaning to pick your brains for a while now. Is this doable in a residential setting?
I'm thinking about building some custom built-in's on a wall that has 10' of finned-tube element. There would be no room for any to remain. Could the finned tube be enclosed inside the built-in, provided there's sufficient free area of grating above the suspended fin-tube element, as well as grating near the floor to allow cool air to enter?
I've seen this before in an old train station, heated with hot water. The element was suspended under the tops of the bench backs that line the perimeter of the station. There were intake grilles at floor level as well. Seemed to heat really well in winter with such tall ceilings. Is this sort of thing doable in a residential setting, with 3/4" finned-tube?
    EBEBRATT-Ed Member Posts: 20,482
    Yes. Just make sure the openings are large enough. You need air coming in the bottom below the fintube and out the top. The fin tube when hot acts like a chimney
    NTL1991
    EdTheHeaterMan Member Posts: 12,508
    edited September 2024
    To calculate the actual heat output of that home made design would be difficult, but it will work. I believe that you can use the elements of any common brand of baseboard element only. They do sell element only.
    Use the ratings of the baseboard as a starting point. If the air way you create ends up with more cubic foot of convection air passing by the element then you may get a little better performance that the baseboard ratings. If, however, you end up with less air flos then you will end up with less heat output.
    NTL1991PC7060
    Try to make all the air exiting out the top pass by the element.
    like the left illustration. If you have room for air to bypass around the element, then the radiator will be less efficient. See the right illustration
    PC7060
    mattmia2 Member Posts: 17,476
    The commercial installation is probably a convector element or a Trane hidden convector box or a competitor but it works with fin tube as well like others have said. i have seen this built in to kitchen cabinets where they had an intake in the toekick and a slot under the counter for the hot air to rise out.
