Carlin ez1 issues
Dadam
Dadam Member Posts: 1
older Carlin ez1 burner
Runs for 3-5 seconds no flame, stops. Goes through restart process. No flame, good oil flow out the bleeder, no oil from outlet of pump. Any ideas, solenoid valve???. The run 3-5 seconds stop restart make me think controller perhaps
  • Big Ed_4
    Big Ed_4 Member Posts: 3,551
    Plugged pump strainer , slipping dive coupling , my first thoughts …
    EBEBRATT-Ed Member Posts: 20,482
    If you get good flow out the bleeder and nothing out of the nozzle line then it is the solenoid.
    SuperTech
  • Jalen_Jalen2006
    Jalen_Jalen2006 Member Posts: 78
    solenoid valve, check coupling. Check for any leaks see if you’re sucking in air anywhere. Put a pump pressure gauge make sure you’re building pressure and holding it. Not much info to go off of
    HVACNUT Member Posts: 7,526
    What's the voltage at the oil delay valve when powered?
    What's powering the burner circuit, B1 from the aquastat, or TT at the Primary?
    What model Primary?
