Vintage Shower Faucet Handle search
Hi
I am searching for a handle that will fit a 5/8" stem, tightening with a screw not from the front but into the handle/against the stem
Would be great if I can match or get a pair.
What suggested replacement is made to fit this type of stem?
All leads appreciated!
Thanks for the help
This look like a universal replacement that had a handle and some inserts to fit some of the common manufacturers' broaches. Is there a screw in the middle of that rusty steel piece? That part should come off then you can figure out what broach pattern it is and find a set of handles to fit like the OEM parts.
2 -
Hi, Something like this?
Yours, Larry
Check with the Sink Factory in Berkeley. They are sure to have a set.
thecrew@sinkfactory.com8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Kissler in Carlstadt nj for sure
Robert W.
Energy Kinetics
Kissler is where we sourced a full rebuild kit for an American Standard tub set. The parts were made in Taiwan but they were pretty good quality and fit.
- 120 Geothermal
- 169 Indoor-Air Quality
