Bad gas valve ? Was replacement necessary?
leaking
leaking Posts: 153
edited August 2024 in THE MAIN WALL
I have a Weil McLain Lgb-6 dual gas valve unit. Both gas valves have have a different number. In November of last year it would not fire. I called the boiler installer/ repairman I’ve used for 50 years. He said I needed a new gas valve (they came as a pair) and I had him replace most everything else since he was there. Bill was $ I paid immediately, he received payment.
I did ask here at the time how to figure what was wrong but then I gave up and hired the pro. I needed heat .
I learned the guy that came over bought out the company I had used for 50 years, I didn’t feel my trust in him.
Since paying him he has tried to bill me twice again for the full amount . I submitted proof of payment the first time, and a fu, the second time. I think he must get bites on his dishonest fishing trips !
Now I question if the gas valves were ever bad and want to verify them as bad. I put 24v to the MV terminal then PvMv terminal and heard it click on one gas valve, the second valve made no noise. Is this how to check a gas valve ? If it checks ok I will send them to Honywell for verification.
Thank you
IMG_8524.png IMG_8523.png IMG_8525.png IMG_8525.png IMG_8524.png IMG_8523.png
    HVACNUT Posts: 7,749
    The V8943A is a single stage valve, while the V8944N is a 2 Stage valve.
    Can you show the whole wiring diagram to see what's OEM?
    mattmia2 Posts: 18,254
    edited August 2024
    No click is probably a good sign that it was bad. If they needed to replace both is another question. There could be a few reasons. The other question is if they set it up properly after they replaced it.
    it is very possible for someone to be a good tech and bad at running a business.
  • leaking
    leaking Posts: 153
    tomorrow I will get a photo of the schematic.
  • leaking
    leaking Posts: 153
    here are schematics . How do I test if the valves are bad ?
