Old NRC
I have an old 1950's house. One of the heating systems is a wood/coal furnace. I've never used it since purchasing, but would like to try it out as the NG is very costly during winter time.
The plate is not readable, no manual for operation and no prior knowledge on the system.
There's 2 temp wheels what are they for?
That that I can read on plate is NRC heat exchanger series.
Rear looks like a motorized flapper for vent/air
20240813_084203.jpg 20240813_084210.jpg 20240813_084329.jpg 20240813_094634.jpg
    hot_rod Member Posts: 27,707
    I would have a boiler pro look at it. Safety controls and valves may need to be updated. I'm not sure the flue piping is to code.
    Do you have access too low cost wood or coal? A place to store it and keep it dry?
    It takes some care to fire a boiler like that, you need to adjust the firing to the load to prevent over-heating.
    You will certainly have a warm basement when you are running that beast.
    EBEBRATT-Ed Member Posts: 20,394
    The aqustat on top of the boiler runs the red circ pump on the left side, what the other strap on aqustat does I can't tell.
    Running that system is a "hands on" experience and is not set it and forget it. You also need some control to prevent an overheat situation. Maybe a dump zone.
    Steamhead Member Posts: 18,625
    It's actually a "Heat Extractor". These were very common back in the day. I'm surprised that one is still there and set up for coal.
    Check your local regulations. In some places such as Baltimore, coal-fired residential heating units are prohibited, because they make a lot of smoke.
    Consulting
  • PRR
    PRR Member Posts: 224
    edited August 2024
    Hard to imagine any fuel cheaper than street-gas. If heating with gas is painful, you want sealing and insulation. The difference between my 1830s house and my 1980s house is remarkable. Good fiberglass was available and waiting in gas-lines focuses your priority. Glen did a bang-up job here in the 1980s.
    Yes, you can find a truckload of 'free' wood (come to my house), maybe even some sad old coal 'free', but ongoing past the first load it is labor and hassle.
    HVACNUT Member Posts: 7,507
    IMO, you've got a 95% Weil Mclain Ultra Gas sitting there with a brain, doing nothing. I'd gladly trade the cost of a few dollars extra for gas and save on my labor. Up and down and up and down and up and down.
    Is the WM hooked up and safe to operate?
    What provides domestic hot water?
