Fan speed for heat pump
When a heat pump is in heat mode should the fan cfm be lower than when in cool mode or the same? When I wire it up just wondering what would be best. I can wire it either way just adds a relay.
John
    EBEBRATT-Ed Member Posts: 20,634
    If your talking the indoor fan which I am sure you are more cfm would be required on heat do to the heat of compression from the compressor needed to be rejected. On cooling the ahu should move 400-450 cfm/ ton. On heating it would likely be about 520/ton.
    EdTheHeaterMan Member Posts: 12,581
    Most of us are in he habit of leaving the fans speed for a heat pump the same for heating and cooling. Not saying that is the best way to do it, just saying what is.
    HVACNUT Member Posts: 7,566
    edited July 2024
    You adjust fan speed, you adjust the refrigerant pressures.
  • johntrhodes81
    johntrhodes81 Member Posts: 53
    Thanks this is helpful. I increased the indoor airflow and got the house to cool better. I have a txv system and my subcooling went from 12 degrees to 1.5 degrees when the airflow was increased. So had to add some refrigerant to get the subcooling back inline.
    So I definitely won't lower cfm when in heat mode.
    Thank you
    John
