Draining water from water heater to clean
Frank12345
Frank12345 Member Posts: 7
hey, im trying to clean out my water heater, and ive been draining it for 2 hours now. The water and gas are turned off. Granted, it is coming out slowly because its probably clogged, but i have filled up now 8-10 full home depot buckets of water
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,622
    How large is your water heater? What size buckets? Maybe the shutoff valve isn't working.
  • Frank12345
    thanks it finally finished. Now the water is brownish though, before it was clear and it drained clear
    mattmia2 Member Posts: 17,466
    the drain is a bit above the bottom and the dip tube will stir up stuff as fresh water enters, you'd probably get more out with the water on and flushing a couple buckets out the drain
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,159
    Hi, If you're going to try and remove sediment from the tank, it is best to replace the stock drain valve with a full port ball valve. It will let chunks of sediment through, and not be damaged by the sediment when being closed. I like to use a plastic-lined steel nipple between tank and valve to prevent any rusting. Then you can much more effectively flush the tank.
    Yours, Larry
    mattmia2Alan (California Radiant) Forbes
