Vaillant vibrating at startup??
cemil2565
cemil2565 Member Posts: 6
Why is this vaillant ecotec 32kw gas multiboiler vibrating at startup? It really wants to shake idk why, is it dying while tryna heat up the radiator water?
    Steamhead Member Posts: 18,531
    Sounds like it might be an ignition problem. Time to call a pro. Where are you located?
    Consulting
  • Natural gas or propane? I'd hire someone with a manometer to check gas pressures and also a combustion analyzer to check the fuel/air mix.
    GGross
  • cemil2565
    Iam in belgium vilvoorde, couple months ago there was a technician come by our subscription from the gas/electricity company, everything was fine, I don't really remember but there was moisture inside and someting small needs to be changed, maybe that does it,
  • cemil2565
    Natural gas from ground
  • cemil2565
    I did record a new video of 3 mins, as you can see it iam not an expert but it's struggling, but eventually it heats up really good, only the beginning part is mysterious,
    Call them back. This should not have happened. Ask for a supervisor.
    Consulting
