Are heat trap loops necessary on a water heater (indirect) with IFCs in a mixing valve?
ThatF_inGuyInNY
Member Posts: 64
Using a caleffi TMV with integral check valves. I had it all designed for heat traps (12" rise) as the manual instructs. But I got thinking that they are probably not necessary if the TMV have check valves. Any thoughts on this?
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
