1920's Toilet Shroud
Looking for one of these, but in one piece :^ )
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,159
    edited June 2024
    Hi, Have you checked with Urban Ore? 🤔
    Yours, Larry
    Ps, plan B, crazy glue 🤪
    mattmia2 Member Posts: 17,467
    Does that cover the tube between the tank and the bowl? I'm not positive but that bowl looks like a 50's or 60's commercial bowl.
  • dko
    dko Member Posts: 669
    edited June 2024
    EBAY
    Well, might not be the same finish
    PC7060Alan (California Radiant) Forbes
  • Intplm.
    Intplm. Member Posts: 3,081
    It's not easy to find as I'm sure you already know.
    If esthetics are important, you might need to pretty up the piping if you can't find a replacement.
    The one you have is fixable. Some phenoseal for the crack and some color coating similar to what a dentist does to match the pigment could do the trick.
    Maybe some linen or biscuit-colored caulk? Something that might match and come close to hiding the crack possibly?
    If you glue the crack back together and reinforce it with a strut of some sort on the back you can paint in the crack in such a way that it is barely noticable, especially down where it will be.
    Intplm.Alan (California Radiant) Forbes
  • I checked with The Sink Factory and they had nothing. Urban Ore is a good suggestion.
    @mattmia2 The date stamped inside the tank lid is 1928. And yes, that's the cover for the chrome pipe between the tank and the bowl.
    @dko Couldn't find one on eBay.
  • PC7060
    PC7060 Member Posts: 1,843
    edited June 2024
    @Alan (California Radiant) Forbes - click on the EBAY link @dko provided
  • Ah! Thank you!
  • JH3550
    JH3550 Member Posts: 33
    I’m a homeowner so my experience is limited, but I had good luck with this company that finds and sells antique plumbing fixtures. They are in California, but ship everywhere.
    Bathroom Machineries
    deabath.com
    209-728-3860
    Alan (California Radiant) Forbesmattmia2
