SHORT radiator union options?
Hi all,
For purely aesthetic reasons, I'd like to move this (one pipe steam) rad as close as possible to the riser. Swapping out the valve for a standard iron union saves maaaaaaybe 1/4"overall.
Any slick ideas out there to accomplish this? The rad tapping is 1". Was hoping for a brass "spud + nut minus the valve" type fitting but can find no such animal. Yes. I'm OK with not having a valve here.
Thanks!
Patrick
  • AdmiralYoda
    AdmiralYoda Member Posts: 798
    edited June 2024
    In the picture, what is to the right of the valve? Is it just a 90 degree elbow? If so, consider installing a 90 degree valve instead of a standard elbow and straight valve and you can get rid of 3" or so.
    Intplm.Mad Dog_2
  • PatrickNorth
    PatrickNorth Member Posts: 33
    Ah- sorry. The straight valve enters a T (the riser continues to the second floor) so I can't use a more typical "90" valve.
    Thanks,
    Patrick
    EdTheHeaterMan Member Posts: 12,507
    edited June 2024
    PatrickNorth
  • PatrickNorth
    Thanks Ed- from there it was a quick jump to male/male unions! Never had a use for one before- gotta love The Wall!
    Thanks,
    Patrick
