A Pellet Stove Survey - Updated with Results!
I'm sharing this survey on behalf of our friends at the Alliance for Green Heat. If you use a pellet stove, please consider taking this 2-minute survey.
The Alliance for Green Heat promotes modern wood and pellet heating systems as a low-carbon, sustainable and affordable energy solution. The Alliance works to advance cleaner and more efficient residential heating technology, particularly for low and middle-income families. Founded in Maryland in 2009, the Alliance is an independent non-profit organization and is tax-exempt under section 501c3 of the tax code.
The Alliance for Green Heat is trying to get broad participation to help the environmental community, and state and federal agencies understand why people use pellet stoves, how they use them, and other demographic information.
The survey does not ask for your name, address or affiliation - only the state that you live in, how long you have heated with pellets, whether it's your primary source of heat, if your stove is reliable and a few other questions.
Anyone filling out the survey is also eligible for one of several $75 gift cards that the Alliance for Green Heat will be giving away.
Thank you!
President
HeatingHelp.com
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
