Anyone able to ID this baseboard??
Brappy129_
Brappy129_ Member Posts: 2
I’m was hoping to add one more baseboard in my living room the same as my others but I can’t find a manufacturer anywhere, any ideas?? Thanks in advance
    EBEBRATT-Ed Member Posts: 20,172
    Not one I have ever seen.
    EdTheHeaterMan Member Posts: 12,173
    It is a radiant baseboard panel. There are no convection air currents involved. I have come across it years ago when I worked at a Supply House for 2 years. There are 2 pipes (1/2" nominal) attached to a piece of metal. Those pipes take heater water at higher temperature (like up to 190°) the makes the metal get hot, then the heated metal cover offers radiant heat to the room. At the far end of the radiator, you can make a u-turn or continue to another radiator. Let me see if I can find some Specifications.
    edited May 2024
    https://www.hydronicalternatives.com/wp-content/uploads/2023/12/Radiant-Panel-InstallationGuide.pdf Looks like on page 3 Table A indicates that the heater have about 200 BTU/Ft which is less that half that of Finned-tube Baseboard. So a room that might require 10 feet of regular baseboard, might need 25 feet of these baseboard panels as the same water temperature.
    kcoppBrappy129_Alan (California Radiant) Forbes
  • Brappy129_
    thanks a lot!
    hot_rod Member Posts: 27,452
    hydronic alternative has some of that. There. We’re a number of brands imported years ago. We had issues with electrolysis on the copper to aluminum threads
  • GW
    GW Member Posts: 5,184
    ahh yes the low BTU stuff, be careful with BTU
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
