End of season best practices?
Now that it's officially warming up and my heating system isn't getting any use, is there anything special I should be doing till winter comes again?
I've got a new Laars combi that goes to aluminum plates via PEX though two manifolds. The water is from the softener, but otherwise untreated. Yesterday, I descaled and flushed the DHW side of the boiler. I also drained my SEP4 for a few seconds till the water was clear.
Is there anything else I should be doing? Any tricks of the trade that will help with longevity or get my system ready for winter?
    hot_rod Member Posts: 28,065
    If it is a combi the burner will be cycling and most of the functions continue to work. I'd pull the burner and do a combustion clean and check ever two years.
    I'll bet there are some instruction videos at the Laars site if you are doing your own maintenance.
  • SteamtoHotWater
    SteamtoHotWater Member Posts: 123
    I'll definitely look into Laars' recommended maintenance. The unit came with a ton of spare washers and doodads - I'm sure for a reason. Mine is only six months old, so hopefully I'm not due for too much.
    But in terms of the overall system, is there anything I should or shouldn't be doing for the off season? Like, I definitely should not be draining the water, correct? Should I be treating the water?
    What type of water did you fill with. Not many areas in the US have water that meets the requirement of the boiler manufacturers. And now I see the pump manufacturers adding water spec to their manuals.
    Here are a handful of boiler manufactures specs. Hardness, TDS, and chlorides are biggies. Also some affordable test kits.
    Screenshot 2024-05-04 at 6.45.43 PM.png Screenshot 2024-05-04 at 6.43.34 PM.png
  • SteamtoHotWater
    I just filled it with municipal water run through my softener. I did use some hardness test strips and the color seemed near(ish) to good. Definitely did not test for chlorides, so I'll look into the links you provides - thanks.
    So, in summation: there's really not anything I should be doing to my system as it lies dormant for the next six months, correct?
    Not really, your boiler never really goes int off season mode if it is a combi.
    The manual should tell you the suggested service intervals. The control may also alert you of scheduled maintenance.
  • fixitguy
    fixitguy Member Posts: 99
    I remember some years ago taking the Buderus training and they recommended flushing, combustion testing, cleaning the catalyst, and then refilling with a special glycol mix. On a yearly basis. After that, I decided to not install or service modcon boilers and I've never regretted that decision 😅
