Steam Convector Air Valve Installation
Hello,
My old Arco cast iron convector (one pipe steam system) in my bedroom is making a lot of clicking noises when the heat is on. I tried to implement all advice I received on this forum the last year, but alas the noise is still there…I suspect that some nipples connecting sections got loose. Anyway, once the heating season is over the next month, I plan to remove this old one and replace it with new steel convector (OCS S840) (already bought).
Air valve on my old convector (see attached pictures) is on pipe 1/2 1/8, so I can use regular angled 1/8 valve. My new convector is tapped 1/2. My question is: do I really need to install pipe first, and then air valve or 1/2 1/8 fitting plus straight air valve will suffice? What is the reason why air valve on my old convector is elevated and not attached directly to convector?
Thank you in advance for your advice!
Got it! Thank you so much. It is an apartment building in NYC, top floor, and the steam pressure is much-much above normal (they do it to comply with the City's regulations), that's why air valves not last long…So definitely I need to elevate the air valve and will do it!
I'd be interested in seeing the regulation that says they have to run it at a specific pressure.
You can also get straight air vents, that is what is usually used on convectors.
I'd bet it is to comply with keeping the temps at a certain level. You know the old crank it up and it heats thing, which we all know is wrong.
1 -
Is it actually the vent the vent? My convectors "click" when the heat comes on from 'cold' - mild expansion noises but don't when the system is consistently hot/warm.
Thank you, guys, for your advice!
I already dismounted the old monster convector (using crowbar and breaking sections) and will install 1/2 x 5.5 in. pipe and 1/2 x 1/8 elbow for regular angled air valve.
P.S. I asked my building's super about the pressure, he said it is very high, but had no actual numbers. 5 year ago, the Board installed the new more compact boiler, and it looks like whoever installed it did initial settings.
As for pressure, there is no specific psi, only regarding temperature:
Heat Season (October 1st to May 31st):
- Daytime (6:00am to 10:00pm): If the outside temperature falls below 55°F, the indoor temperature must be at least 68°F.
- Nighttime (10:00pm to 6:00am): The indoor temperature must be at least 62°F, regardless of the outdoor temperature
I worked for nycha in heating, our plants would normally run between 6-8 psig our boiler pop safety's would pop at 10 psi mostly sub atmos vac pump distribution
-1
- 125 Chimneys & Flues
