how do I measure pump cutoff on the Riello?
alias2102
Member Posts: 10
I do have a Riello manometer and vacuum tester. However, it doesn't fit the nozzle port or a nozzle line. Could you suggest an adapter size?
Usually, you'd connect the 3/16" flare fitting, but Riello is all metric.
Thank you
Thank you
