Boiler feed pump overfilling
Looks like this has been going on for a couple years. Got called because of water on boiler room floor. The receiver is full, but the PRV is still feeding. Float problem?
    EBEBRATT-Ed Member Posts: 20,347
    edited March 2024
    Yes, it is on the RH end of the tank. There is a float inside like a toilet tank float. See what the water pressure is on the supply side of the float. I think 30 psi is max.
    If the boiler pump is constantly cycling (like every 30 seconds) then you have a bad check valve between the boiler and the pump. If it doesn't get fixed you will kill the boiler.
  • Pumpguy
    Pumpguy Member Posts: 806
    What is make up water supply pressure? Generally, mechanical float valves are not recommended when supply pressure exceeds 50 PSI.
    What is regulated supply pressure downstream of PRV?
    A better make up water arrangement is a float switch and solenoid valve.
    Typically this is the preferred arrangement.
  • targetman74
    targetman74 Member Posts: 6
    The PRV is 25-75 range. Someone wrote set to 20 PSI. First laid eyes on this yesterday. Thinking how could I add solenoid valve.
    @targetman
    Take the original float out and install one with a switch. Wire the switch to the solenoid. Move the MU water to a different tapping. Put a tee in the vent line to add the water if you have to
    Looks like a Shipco Tank? Call the local Shipco rep and they can hook you up
