Pressure loss
MWunsch995
Member Posts: 1
I have a closed system with two zones. Last few days every time my bigger zone turns on (calls for heat) the pressure in the system drops rapidly to 0-5 psi. I know 15 is normal psi..I usually have mine at 20-25 since one of the manifolds has had a slow leak since install. What can be causing this pressure drop??
It could be where the relation of the gauge is to the pump.0
- 125 Chimneys & Flues
- 19 Recall Announcements
