Don’t know what to say?
Simply Rad
Simply Rad Member Posts: 209
edited February 2024 in Radiant Heating
I saw this in a mechanical room last week.
Jeffrey Campbell
  • Simply Rad
    Forgot the picture:
    Jeffrey Campbell
    Long Beach Ed
  • clammy
    clammy Member Posts: 3,257
    Awesome ,some one will live with it ,happy it ain’t me . I guess be happy the sheet rock hides the rest of there handy work most likely just as well thought out ,planned and executed as the placement and running of the pex and the manifold placement .
    Can’t really say much more but as things go ,nothing I see even makes me bat an eye it’s just a well isn’t that special and leave it at that and move on . It’s better that way then to rock the boat as long as it works isn’t that what really matters . These days I think quality and craftmanship of the work really only matters in what people see in there face not the stuff behind doors that only matters when it don’t work plain and simple .
    Get the blinders like an Amish horse .
    Peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
    realliveplumberIntplm.
    hot_rod Member Posts: 27,812
    A pex panel radiator. Certainly the pex fitting dealers like seeing that :)
    A couple inverted manifolds would have saved maybe 100' of pex and a few dozen ells and expansion collars.
    Not to mention the additional pressure drop.
    Long Beach Ed
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,843
    Just imagine how much worse it could have been done... Do you think there's miles of it coiled up atop the Sheetrok?
    GGross
  • realliveplumber
    realliveplumber Member Posts: 354
    One hundred and eighty degrees. Thats all it would have taken.......
  • realliveplumber
    A half a turn. All he had to do was rotate the manifolds counter clockwise a half a turn......
    EdTheHeaterMan Member Posts: 12,497
    I wonder if this might work just as well?
    But you could not clock as many hours as this
    So somebody made some extra money here. And they are probably very proud of their work.
    realliveplumberGGrossDJDrew
  • realliveplumber
    Exactly. Sometimes people cant see the trees through the forest.
  • I’ll bet those horizontal pipes sag when they’re hot.
  • rick in Alaska
    rick in Alaska Member Posts: 1,526
    Well, I believe some of the manufacturers don't want there manifolds installed upside down, so if you have actuators installed, they don't get potentially leaked on. If that was me though, I would probably have used some of the old Heat Link track and just made big loops in the piping instead of all those fittings.
    Rick
  • psb75
    psb75 Member Posts: 1,153
    At least they used Uponor expansion fittings. Those are closest to actual .5" ID.
