Rollie tank heater
Miata
Member Posts: 58
I currently have a 275 gallon Roth tank installed outdoors . A bottle of HOT is added at each fill up, and I have experienced no clogging of fuel line with temps so far as low as 15F. My concern is if it gets colder I believe an intank heater would be a plus in not only warming oil in tank, but supplying warmer oil to burner. Plus I am installing an Tigerstop antisiphon valve on the tank to protect the line between the tank and the burner. Has anyone installed the Rollie system that uses a 12volt prob that fits in the suction pickup that is supplied with the unit? Rollie makes one for the Roth tank and looks rather easy to install. Any help would be appreciated.
- 128 Chimneys & Flues
