LEGIOMIX® Electronic mixing valve
RickDelta
Member Posts: 620
@hot_rod
In reading the Legiomix docs, It states, " besure to have "anti-scold" device on every fixture to prevent skin burns" ..... when using its high temperature (180 F) legionella kill mode.
I think most motels have shower cartridges with the anti-scold feature, but almost never see anti-scold at the vanity faucet.
...... your experience in this?
Thanks!
Thanks!
If you use the Legionella mode, during that period of time the water will exceed the suggested 120 safe temperature. The point of use ASSE 1070 valves are the final protection at the fixtures.
ASSE 1016 listing may be on tub and shower valves with a limit stop set at 110.
Type P is a pressure balance valve
Type T is a thermostatic
Type T/P is a thermostatic/ pressure balance
More expensive valves like Grohe for one, tend to be T/PBob "hot rod" Rohr
Living the hydronic dream0 -
....... and would you agree "most" motel sink faucets are NOT thermally protected?
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 963 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
