Shower Pressure Balancing screw.
Is it a Kohler RiteTemp valve like this. Is this a new problem, has it worked in the past?
It may need a new cartridge. The stop collar is really to limit how hot it goes.
Loosen the set screw, turn the valve to the temperature you want and tighten. Make sure the water heater is up to temperature first.Bob "hot rod" Rohr
Living the hydronic dream0
