Dunkirk PWX burner drop
mrbean8686
Member Posts: 1
Hello folks got a Dunkirk PWX series water boiler that I have been experiencing burner drop according to my hvac tech. It usually fires twice or three times when the boiler has sat for more than an hour, when its hot or warm it usually fires in one try. I swapped out the ignition module with the same oem utec 1003-600A series the new unit has helped with re ignition with continuous retry, the old one didn't do that anymore. I have also replaced the spark assembly, I do have a one wire spark system. Any ideas whats causing this are greatly appreciated thank you.
https://youtube.com/shorts/4KEuG0L5Q1Y?si=cjtyC3Vfj0D53K67
