Commercial water heating, storage tank vs indirect
Ngriswold
Member Posts: 1
Hello, I do a lot of commercial service and installs. I frequently see DHW boilers (a LOT of burkay copper coil) to one or two storage tanks for buildings hot water. I rarely see an indirect or direct fire water heaters. I am curious what the advantages are to the storage tank system vs. an indirect or direct fire tank type. I’ve done lots of googling and can’t find anything.
Thanks!
Hi, As a very general rule, anything that has storage will give less temperature fluctuation than any sort of on demand approach... assuming the storage is correctly sized for the load. This matters for showers, where people will feel a one degree change, less so for other uses. Not sure that's what you were asking about though
Yours, Larry1 -
