Viesmann fan motor
hwark1
hwark1 Member Posts: 1
My vitodens 100 fan motor is starting to squeal. Does it have bearings or bushings. I’d like to know what size bearings before I pull it off if it has that.
Herman
    EBEBRATT-Ed Member Posts: 20,755
    I doubt you can rebuild it. Mod Cons are usually sold as a fan assembly which includes the motor and the blower wheel. $$$$$
    kcoppAlan (California Radiant) ForbesDerheatmeister
  • Beaver33
    Beaver33 Member Posts: 24
    I have the identical fan installed in my Vitodens installed in 2010. Although the fan is sold as an (expensive) assembly, it is possible to get into it. I was able to repair an electrical problem on the control board inside the fan.
    I want to replace the ball bearings in my unit in the next few months. I have seen bearing replacement of similar fans on YouTube. I am not aware of any written information giving the specifications of the bearings. You may need to purchase replacement bearings after you remove the originals and determine their specifications.
    GGross
