Safety of Maxitrol Regulator In Basement Above Furnace
tajohnson92
tajohnson92 Member Posts: 1
Hi! Newbie to owning a home with propane heat here.
I had a tech come to clean/service my furnace who flagged the propane regulator being above my furnace as a huge safety issue. Irving sent out a tech who told me it’s within code because it’s a maxitrol vent limiting device. Fire Marshall told me it’s fine and reaches “minimum requirements”.
However, it is right above my furnace. If anything goes wrong - isn’t this a huge safety issue? Should I push to move this regulator outside? Would you be comfortable with this?
I have a 500 gallon tank on the other side of my property. See the lines and basement situation below.
    EBEBRATT-Ed Member Posts: 20,478
    Probably not the best location but probably not against code. Should be a non issue.
    mattmia2 Member Posts: 17,466
    Is using pvc for the vent connections allowed?
    EBEBRATT-Ed
    @mattmia2
    I wouldn't but seeing it is outdoors I don't see an issue.
    I just noticed that cracked joist. Unless there is something I'm not seeing picking up that load I'd be concerned about that.
