Why does my zone valve use 40v transformer?
drosner
I’m replacing my taco circulator zone control and I have one zone where a prior owner/contractor put a zone valve along with a zone circulator. I’m pretty sure they did that to prevent flow when that zone isn’t on. Either way it works just fine.
Here’s my question…I see they added a 40v transformer and in reading the Taco 571 docs it also indicates to use a 40v transformer. However the specs of the 571 say it’s a 24v device. Why does Taco say to use a 40v transformer to power a 24v valve?
va stands for volt amp
vac stands for volts alternating current8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Uh thank you for clarifying and I feel pretty stupid right now!0
24V X a .9 Amp zone valve = 21.6 VaBob "hot rod" Rohr
Living the hydronic dream0 -
Don’t bother. We all have a lot to learn.drosner said:Uh thank you for clarifying and I feel pretty stupid right now!8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Two btu per sq ft for degree difference for a slab0
- 135 Chimneys & Flues
- 16.2K Strictly Steam
