Radiant Heat Rookie
We purchased a new/used home and we have never had a radiant heat system before so this may be operator error… we never turn our thermostat on yet our home has been a toasty (too hot) 75-80 degrees all winter. Since the thermostats are off we have to open our windows to regulate the heat. What are we doing wrong?
    EdTheHeaterMan Member Posts: 12,497
    Interesting. Is the house haunted?
    Can you take a picture of the thermostat, the boiler from floor to ceiling and what type of radiant piping/tubing or radiators you have. In other words "Where is the heat coming from?" Is the floor warm?
    Mad Dog_2
  • Ed
    I’m not sure if the photos came through… will try again.
    hot_rod Member Posts: 27,812
    You have a bunch of zone valves, the silver cubes under the green box. One of those could be stuck open. Lights on the green box tell you if the thermostat is calling for heat. What lights are on?
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,671
    The House isn't in Amityville long Island, ? Is it?  Ha ha 😂 🤣 😆 😄 Mad Dog 🐕
