WM combi heat exchanger bad in 3 years
I'm assuming this isn't normal, is there anything typical that causes such a failure this fast that I mention to her?
Unit runs on LPG and they have well water. Unfortunately I don't know much more than this at this point.
I doubt it's leaking, but how do these work with domestic hot water? That's fresh water being fed into it somewhere?hot_rod said:Is it leaking? If so where?
Water quality
Inadequate flow
Combustion not dialed in
The other 3..........I wouldn't be surprised if all 3 are issues.
EDIT : I just realized you meant is the heat exchanger leaking. I'll ask.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I was thinking in terms of the boiler (HX). Is it the flat plate HX for DHW that is leaking?ChrisJ said:
Water quality
Inadequate flow
Most brazed plate type, O ring connections into a composite block, one or two pinch bolt keeping it together.Bob "hot rod" Rohr
Living the hydronic dream1 -
I'm told the return tube to the heat exchanger is leaking at a factory connection where's it's crimped.
Their contractor is working with WM to try and get it replaced
It sounds like it's caused damage to a board as wellSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 133 Chimneys & Flues
