Propane Regulator failures
Chad Reed
Chad Reed Member Posts: 5
Has anyone noticed an increase in LP regulator failures? It seems to me they are not lasting as long as they used to. We see them more now when dealing with the modulating equipment, as well as on systems needing higher inlet pressures. Just figured I would reach out to see if anyone is noticing this as well.
  • GGross
    GGross Member Posts: 1,969
    Yes with modern equipment I think we are just noticing the failures more. If the regulator doesn't act quickly enough many times the equipment will throw an error code where older equipment would be content to burn out of spec. I also handle issues that arise from improperly purged LP tanks several times a year now.
    EBEBRATT-Ed Member Posts: 20,478
    I have had issues with moisture in the regulator causing sticking and freezing.
    hot_rod Member Posts: 27,838
    Fuel quality?
  • JUGHNE
    JUGHNE Member Posts: 11,603
    Could modulating equipment be "working" them more?
    More flexing internally on parts.
    mattmia2 Member Posts: 17,466
    edited December 2023
    I wonder if the type of valve that works by modulating the gas flow based on the air flow can transfer turbulence and such as vibration in to the diaphragm of the regulator.
