Check valve rattle
Fluke216
Fluke216 Member Posts: 33
The check valves on the left are rattling mostly when both pumps are running at the same time. These pumps also have an internal check valve which I wasn’t aware of until I was installing the pumps. I’m thinking about removing the check valves before the pumps that that may eliminate the noise.  An input is appreciated thanks.
  • dko
    dko Member Posts: 669
    edited December 2023
    You are double checked if you still have the IFC inside the circulator (it comes with one).
    You will want 5-10x pipe diameters downstream of the check as well as the opposite side though not as many pipe diameters for a more laminar flow. You will have quite some turbulence there.
  • Fluke216
    Yea right now it is double checked
  • dko
    edit: sorry didn't read the text below the photo completely.. you were already aware of the ifc.
    Feel free to remove the brass spring checks
    hot_rod Member Posts: 27,812
    Are the brass checks on the inlet side of the circulators? You don't generally want any flow restricting device before a circulator.
    And on the discharge it may be oversized and the pump cannot push it open completely.
    Just the IFC will do the job.
  • Fluke216
    Ok awesome thanks I was copying a model of an radiantec manifold they had check before but a different style ok yea I’m going to remover them thanks guys
  • Fluke216
    Yea they are in inlet  side
    EBEBRATT-Ed Member Posts: 20,467
    That would be an expensive removal if it was piped in Pro Press :):):)
    You know me I always look at the negative :):):)
