Utica Boiler- Obsolete Gas Valve
Hello, I am inquiring on behalf of a contractor in one of our industry organizations. He has a Utica UB 90125 gas boiler with a bad gas valve. Manufacturer says the valve is obsolete and he is not having luck with third party vendors. The Utica P# 2272140 and Honeywell P# VK8115F1100-003-125.
I saw pictures of the valve and it looks very close to the valves we have in stock for WM Ultra boilers, of course the Honeywell numbers aren't an identical match. The gas valve itself is VK8115V 1036 4. The WM we have in our shop is VK8115V 1127 4. Wondering if anyone knows if these valves are interchangeable. Thank you for the help!
  • The Honeywell number in the first paragraph includes the venturi. I am thinking that just the valve needs replacing and they can reuse the venturi.
    HVACNUT Posts: 7,749
    edited December 2023
    Where are you located? Sid Harvey's might be able to cross it.
    But they only deal with the trade.
  • tim smith
    tim smith Posts: 2,935
    I don't think you will find good cross here in USA for that. Those are mostly made in Europe and sent over with the burner assy and heat exchanger. That's my take at least.
