Gas line size for range and dryer
I have a 3/4 " gas line that runs ~100 ft. For the last few feet of the run can I convert to 1/2" gas line for the dryer and the range (stand burners and oven).
Thanks.
  • If all you have is the range and dryer you usually need 3/4 to the range and 1/2" to the dryer. At around 100' you will be pretty much maxed out on the 3/4" pipe just for those two appliances.
    I am assuming natural gas and not propane.
    branimal
