Filters
ksk
Member Posts: 7
in Oil Heating
Only the filter on a tiger loop . No other filter from supply. OK?
Tiger Loop Ultra?
There can't be anything after the Tiger Loop.
This is acceptable: Tank > overhead fuel line > oil filter > Tee fitting > tiger loop inlet from branch ^ tiger loop inlet from run.
This is acceptable: Tank > overhead fuel line > Tee Fitting > tiger loop ultra on branch ^ tiger loop ultra on run.
Both tiger loops: Outlet > burner supply > burner return > tiger loop return. Just like the picture on the box. No other filters between the tiger loop outlet and the burner inlet is required.Edward Young Retired
