Peerless PCB-52 Fill issues
mscarneo
Member Posts: 1
I have a Peerless PCB-52 There have been seveal times we have no heat or hot water, when we check the system says fill. this has required a service call and long waits. I watched how they filled it, and I tried that it worked, but why is it happening it is not right that this is a manual operation.
Would like to see some pictures posted so we can get a better idea of what might be happening.
Your system is losing water. Your auto feed is not working or cannot keep up with the needed fill and is there for shutting off for protection purposes.
When you manually feed the boiler "it works" as you say.
You most likely have a leak on your system somewhere.
Find the leak and or correct your auto-fill valve, that is....if you have one?
Pictures?
- 128 Chimneys & Flues
