Auto shutoff valves for hot water heater, or whole house?
Hi Everyone,
I have a floodstop shutoff valve on my hot water heater that is not longer working. I understand the Taco Leakbreaker is a similar product. Does anyone have any long term experience with the Taco product? For whatever reason, the floodstop seems to have a 3-4 year life...maybe that is just normal for these devices.
Also, I am now considering if a whole house shut off is a better way to go. I only know of Moen Flo which seems to get mixed feedback. Any other solutions I should be considering? I am looking for peace of mind when travelling that if there is a leak there is a way to manage it so I do not come home to a complete mess. I do shut off the water at the washing machine when we are away.
Thank you, Howie
    hot_rod Posts: 28,863
    What is the failure in those flood stop valves?
    Assuming there are no leaks in the boiler system, you should be able to shut off the entire home without a problem.
    A low water cut-off on the boiler could be added for extra protection. Although some of those have a questionable life expectancy also. Certainly do not want a boiler lock out while you are away :)
    Lyle {pheloa} Carter
  • I would stay away from the Taco leakbreaker. We have been getting quite a few callbacks on them with nuisance issues.
    We will not install them anymore.
    We have used the Moen whole house shut off, and have not had any issues with that.
  • The floodstop valve is stuck in the open position. The motor cant close it. I tried closing it manually and it wont budge. I will either have a new floodstop installed, or switch over to the Moen. Much appreciated, Howie
  • GGross
    GGross Posts: 2,123
    I like the moen valves, though I had a couple of contractors break the plastic union nut which is not offered as a replacement part as of this comment so breaking that means you need a whole new not-under-warranty valve. For those contractors we now sell these ones by streamlabs
    https://streamlabswater.com/pages/streamlabs-control
    What valve is under the hood of that brand? Do they make their own valve? Looks like a full port ball valve?
  • @GGross , thank you for the input on the streamlabs device. I will review both this and the moen with my plumber. This seems like a better route to take than a device like a floodstop.
  • dko
    dko Posts: 669
    edited December 2023
    The valves need to be exercised time to time, it's an issue because the valve has probably never been closed for those 3-4 years and build up locks em up.
    But to be fair, nearly no homeowner exercises any of their valves unless educated on the topic.
    The floodstop is a simple product, it works as it should and is very cost effective.
    Whole house shutoff options are
    FloLogic
    Leak Defense
    Phyn
    Flo by Moen
    Water Hero
    Above products are what is normally accepted by insurance companies around here (nyc).
    If you have insurance, I would check with them if they offer any. Most of these companies offer discounts through insurance.
    If I were to design a whole house valve I would add a daily exercise feature . Completely rotate the ball once a day. Somewhere around 2 AM or when it wouldn’t be noticed at all
    The LegioMix 3 way valve has this feature, think of a windshield wiper action cleaning the sealing surface
    dko
  • heathead
    heathead Posts: 252
    Phyn has a water shut-off and monitoring device. It has been a very good system. It does a leak check at least twice a day. It will let you know if you leave a faucet or hose on. It's a Smart valve.
  • Doug_7
    Doug_7 Posts: 266
    I have had WaterCop installed for over 5 years and works very well. Motor actuated ball valve installed on water supply. Remote automatic water-sensor shuts water off. Also manual push-button control on valve actuator. Motor actuated valve on water supply get exercised often because that is the easiest and best way to shut off the water when away. See attached manual.
