Expansion tanks, trapped air
CBRob
CBRob Member Posts: 291
I think all of these tanks are allowed to be installed vertical. How would the trapped air ever get out?
    EBEBRATT-Ed Member Posts: 20,485
    With a bladder tank there is always air on one side of the bladder and boiler water on the other side. The expansion tank acts as an air cushion to keep the correct pressure in the system.
    Wit a bladder tan you need automatic air vents or manual air vents or a air scoop or microbubble eliminator to remove the air from the system.
  • CBRob
    Wouldn't air be trapped under the bladder when the threaded end is down?
    I've always installed them threads up.
  • Intplm.
    Intplm. Member Posts: 3,083
    Nah. After some time the water will absorb the air if any is there at all.
    CBRob
    hot_rod Member Posts: 27,859
    thread up is preferred, thread down or horizontal are acceptable, according to Zilmet instructions.
