Heatrae sadia electric boiler " No Heat"
suds10
suds10 Member Posts: 1
I have a heatrae sadia electric boiler which has stopped heating the water to the radiators. The boiler fires up as normal i have a green light on supply a green light on call for heat and the heat light is also green so the boiler looks like it is operating as normal however the radiators are not getting hot and the pipes from the boiler are also not hot. Just wondered if anyone has any advice on what is preventing the boiler from heating. Thanks
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,159
    Hi @suds10 , Is there a chance that you could post some photos of the boiler and its piping? That would make it much easier for us to give you meaningful feedback.
    Yours, Larry
