Power Purge valve from Dan Holohan, Pumping Away
OG_Simon
OG_Simon Member Posts: 12
From page 48, Pumping Away. The valve arrangement for power purging the boiler. Sounds like a great idea, how would you adapt this concept to the new combi boilers? pics for reference.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,551
    Pipe in a purge valve between the returns and the boiler ...
    Intplm.
    hot_rod Member Posts: 27,859
    You have 3 shown in the blue piping in that schematic.
    Or you could use a single purge ball valve next to that blue manifold, delete the 3 single valves and boiler drains.
    Isolation valves at the pumps, always a good idea, would allow you to purge one zone at a time.
    The version with two purge valves would allow you to connect a purge pump for cleaning or adding chemicals
