Martin Heater Experts?
mtholton
Member Posts: 1
I have a one year old Martin Heater. When turning it on for the first time this fall, it's having issues. We can get it started, but when we try to turn it anything higher than the lowest setting, the gas slowly flames out. It seems like its not getting enough gas? Besmer (Martin) said 99% of the time its a pressure issue. It's at a semi remote location, so getting help has been tough, but had a technician out this evening. They tested the pressure and said it was fine. He indicated they think its a pressure valve thats not opening enough. I'm not sure if he has a lot of experience with them? Anyone else with this heater run into this issue have any ideas?
-1
Are these heaters exspensive to run per month 2000 btu natural gas model
